Crb on stone ?
Mr.cleansalot
JAMES FISHER
along time ago I scrubbed a softer stone with crb and looked to me that it damaged it so I have never tried it again .
What do you guys think or know .
Can I use one or not ?
Once my demo pads are in I can play around but til then need advice .
Mr.cleansalot
JAMES FISHER
no it was more like a lime stone I'm still learning all the different stones I know the most common ones .
It just seemed to through off the look idk I only did a small area and then quit .
I could be trippen .
But don't want to chance it .
Hard to imagine unless the brushes were worn out and you were scratching the stone with the metal frame edge
Mr.cleansalot
JAMES FISHER
No I might have been trippen .
So its all good to run blue brushes on stone ?
Do you guys ?
Old Coastie
Stephen
As long as your brushes are not grit-impregnated, you are unlikely to cause damage. I have one Malish brush for my 175 that has (iirc) 400-grit particles embedded in the nylon. I would bot use it on natural stone, but it works well on tile and grout.
Reactions: Condog
