Are there really $3700 worth of bells and whistles on this scrubber?
http://bonnetpro.com/carpetmax/minifeatures.html
The new Mini Max Mule is the pinnacle of low moisture carpet cleaning equipment. The Never Spill feature is a Bonnet Pro designed exclusive. No matter what position the handle is in, even if the machine is laid all the way back onto the floor the cleaning solution jug will always be in the upright position. This means never again having to deal with a shampoo tank that spills all over the carpet when you’re changing your scrubbing or absorbing attachments.
Your Mini cleans with SETT(Soil Extraction Transfer Technology)which uses specially designed absorption disks alone or combined with a bristle drive for an exceptional clean that requires little moisture – so it's not only green, it's less disruptive because it dries faster than most other methods.Your machine also comes with the Multii Brush System at no additional cost. Combining 9400 bristles with our 220 r.p.m super light weight custom motor achieves over 2,000,000 carpet contacts per minute and this doesn’t even count the contacts the three different insert disks make! Talk about a better clean. You also receive a high quality regular pad drive with no crush bristles. This allows MiniMax users several different levels of carpet care. Straight SETT cleaning, a SETT and bristle cleaning in just one pass or a two step option for heavier soiling.
- • Level 1 - Straight bonnet cleaning. This is very fast and can be used for light to moderate soil removal with a variety of bonnets we make like ProCotton, Plush, or Supima
- • Level 2 - Using your Multii Brush System. With the ProCotton bonnet installed inside the Multii Brush this will accomplish Level 1 cleaning PLUS helps lift the pile and cleans even deeper for more heavily soiled carpets.
- • Level 3 - Now, using your Multii Brush for a two-step cleaning, first install the Revive Encapsulation Pad inside the Multii Brush for maximum scrubbing power. Follow up with either the ProCotton Bonnet inside the Multii Brush for added scrubbing and absorbing on the second pass/step OR you can switch to the included pad drive to use full-size bonnets for maximum absorption on the second pass/step.
