Prochem Titanium wand jet pattern
jcooper
Jerry Cooper
Mine is a four jet and has 11002's in the middle, 95002's outside.
Mark Saiger
Mr Happy!
Mark Saiger
we are using 6 jet and have been running 11002's all the way across with our High Heat Butlers.....
8002..9502....11002...11002...9502...8002...
Its a good pattern and it is what is being used with the 570........
But....if it was not for the kid liking that wand...I would of dumped it a long time ago and replaced it with another 4 jet westpac wand...........
ruff
Ofer Kolton
Are we talking pattern or angle?
The jet's spray coverage (angle) will change depending if you use extenders or not.
With extenders/check valves we use the same angles as above but just have two wands on each truck one set up 02 all the way across and the other set up 03 all the way accords for flushing.
95002 11002 11002 10002 10002 95002 or for the other wand 03 all across angles stay the same.
