red dye remover
sassyotto
Paul
have tried Red 1 which was mostly successful but sometimes took color out, then tried Harvard Chemical Stain Blaster which didnt work as well. Anyone have a magic red remover?
Are you looking for something for synthetic fiber carpet, or for rugs and upholstery Paul?
SteamwayPro
George
I've been using Red Vanish from VacAway for about 10 years. It works for me
I'm VLM now, but was using VacAway spotters even when I was HWE
On nylon you will need heat
Lamesalegend
Cobbs Red Dye Remover, Vacaway Red Vanish and ProsChoice are the 3 best that I have tried. All 3 are equal in my opinion. There the only ones that I feel confident in just spraying on the stain and leaving, no heat. And these 3 don't leave a soil attracting residue
What do you guys do for red stains that might be locked in due to the customers previous attempts?
I have had good results with Red Vanish from Vacaway. You can use it with heat for quick results or just give it time and maybe a second application.
Reactions: sassyotto
Bryce C
DFW
Bryce
I don't have good results with synthetic red stains. I use Red Zone from Bridgepoint. I think I need to cart around my wallpaper steamer and stop being lazy.
Reactions: hogjowl
SteamwayPro
George
Red Stain removers are rarely needed today
Colored stains on Polyester Triexta usually pop right out without any problem
You just need it for nylon
Reactions: SamIam
Cobbs dye stain remover was probably the best I've ever used.
But I don't care anymore so red1 and dye loss is a customer problem for allowing red dye on the carpet.
I clean a ton of cut pile nylon,
Polys and olefins don't stain with red dyes for the most part.
That's why guy who make red stain remover saying spray it on and clean and the red comes out!
Only tested on an a poly carpet hahahahah
