Why Is This Guy Selling His Vortex?
lance
It won't be 72 GGG when the lease is up. Probably closer to 100KKK when all is said and done.
Will there be a newest, most re-engineered, more quiet than the one built before it V or AT at Mikeyfest? Those things are so much fun to look at.
Well gee Lance thanks for pointing that out.
I never knew that I had the only truckmount in existence that automatically had to be talked about with financing percentage figured in.
Yes, there will be VATS @ MF.
lance
Your welcome, your tallness. That's what you get for being out in the lead and causing so much trouble over on the ICS board.
The system hoses should all be crimped with stainless fittings, might as well use 400º teflon core stainless braid urethane jacketed hoses while you are at it.
But would you pay the extra for it?
558 cfm and enough heat for two wands....almost as good as Waldo's unit :lol:
yes....for the less headaches it will give you it would be worth it........................but really..........at that price.should we not expect top quality and the very best anyway...............................
