A good 2 gallon sprayer.
steamron
Ron
For years I've been using a old Gilmore spray.
It still works but I'm getting a little worried about her lately. Any suggestions? some of the stuff out there now is simply junk.
Hard to beat a corded Multisprayer. Get one with a quick disconnect that you can pop off the trigger & lance and pop on the upholstery gun jet.
MS2 I think.
I agree with Chavez
But be aware
Multisprayer isn’t all it used to be
encapman
Rick Gelinas
If you're looking for a good small sprayer it's hard to find one better than the Gentoo.
Numero Uno
Caesar
Drill hole in last one ,add air valve.
Inject with air an go,no moving pats to fail ...
Simply re pressurize when done...
That is if you want to spend under five bucks for permanent sprayers...
First thing I would change is to take the hose out of the cap and put a hole in the side for it. Found it is a pain in the ass with that set up.
Reactions: FB7777
encapman
Rick Gelinas
Any relation to Sal's old penguin?
Yes, it is. After Sal died his widow kept the company running for a couple of years, but it was a lot for her to handle. So the Penguin & Gentoo line was acquired by Sal's nephew.
I miss Sal.
Last time I saw him was at MF in Nashville. We've lost too many innovators of that generation.
Reactions: encapman
Jeff T
It’s just heavy…. What I did was cut the 2’ line off, added a 25’ coil hose- air hose…
Drop @ the door, and spray away…
Reactions: encapman
FB7777
Mind your own business
Says the :idiot:that is spreading rumors that he has on ‘good authority‘ misinformation about a certain manufacturer and is too dumb to actually check his facts
does TCS stand for totally clueless simpletons?
FB7777
You didn’t … I was amplifying the inept gossip well you draw your information from
