right Damon?
What do you vets keep on hand, just in case...?
A spare truck mount
I got that backpack sprayer that Sarti got. I also bought 2 replacement batteries for it. When I get time I'm going to go through my Vibe and replace all the 1/8 ice maker lines. I think your theory may be right about me having an air leak. Hopefully my pump isn't the issue.
Larry, I don’t know what’s happening yet. I need to go through it.are you using in any powders with oxy in the formulation? (mixed hot)
the tiny oxygen bubble release can cause cavitation in diaphragm pumps
I tried to tell himPull the slack if any, cut the ferrule off and start with new ferrule and compression nut.
The nut isn't the problem. And when I put that damn thing on that frickin compression fitting kept jumping out of alignment. So after the 6th time I said **** it. I'm still going to check it, but I don't think that is my air leak. But if I'm wrong I'll admit it.Pull the slack if any, cut the ferrule off and start with new ferrule and compression nut.
Us too, plus enough parts to make another couple!I have 2 spare truckmounts just in case.
