Jul 26, 2020 #1 D Dristar1 Member Joined Jul 26, 2020 Messages 2 Name J.P. i have a prochem legend gt and when i choke the unit to start the gas over flows in side the unit and will not start can someone give me advice
Jul 26, 2020 #2 Cleanworks Moderator Joined Oct 22, 2012 Messages 28,282 Name Ron Marriott Dristar1 said: i have a prochem legend gt and when i choke the unit to start the gas over flows in side the unit and will not start can someone give me advice Click to expand... The float inside the carburetor is stuck. Fix it before you have a fire. Reactions: Hack Attack and Lee Stockwell
Jul 26, 2020 #3 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Name Lee Stockwell You may have a fuel pump with too high pressure. If the original is replaced with an identical looking unit with an over 4 psi output it will soon overpower the float needle shutoff in the carb. Reactions: Cleanworks
