- Oct 7, 2006
- Name
- Dirk Wingrove
There are a ton of things to do out there to improve vac and heat. All I've done so far is....
1. Got the 14" Greenhorn wand with high flow and a glide.
2. Run 2 inch hose to the wand.
3. Removed the throttle stop in order to achieve about 10-15% more rpm's.
That leaves these improvements and more left...
1. Kunkle
2. 2.5 inch hose or 4 to the door.
3. Re-plumb for bigger openings (not sure if possible on boxxer)
4. Find better in-line filter. Not going to ditch my APO. If I don't filter, it clogs.
5. Better CFM's with 12" wand???
6. Post heater to get it really hot ATW.
Right now I'm in Phoenix and the air is so dry that I can soak down a carpet and it will still dry quick. I'm relocating to Lincoln, NE and the humidity is very high. Dry times will become an issue with my current setup.
Which improvements would you recommend. Also, rate them by order of importance.
1. Kunkle
