How much water are you using?
Living The Dream
Swani
Today I cleaned around 1500 sq ft of carpet with my 6 jet, 9 flow at 600psi and used around 55 gal. Of water. Is this close to the amount of water you guys are using?
roro
Ross Craig
You are using about 22% more water than the guru in an area that's almost 50% higher in humidity than his??? I'd be reducing my jet size and turning down my pressure a lot.
roro
You would notice those things if you use 50%
capacity in your first small house Moron!
Reactions: hogjowl
sassyotto
Paul
Id probably be at about 85-95 gallons at 400 psi and 6 flo - same proceedure except with a CRB. Maybe Im doing something wrong.
Reactions: Living The Dream
Living The Dream
Swani
What machine are you running? This was wide open areas with no furniture. There was no idle time so the machine never bypassed water.
