- Apr 17, 2009
- Name
- Kenny Hayes
Or trailer with ramp door. Six and one half dozen other.Box truck, Cimex, lift gate. That combo is a
I like a nice trailer and can back em up with the best of em, but some locations are almost impossible to maneuver a truck and trailer into.Or trailer with ramp door. Six and one half dozen other.![]()
Certainly an award winning chili chef knows to stir slowly and thoroughly2 - If you just poured the powder into you tank, then that’s the problem. It has to be mixed up first.
But not in OKLAHOMA for the most part. Church parking lots, roll and goI like a nice trailer and can back em up with the best of em, but some locations are almost impossible to maneuver a truck and trailer into.
Good point. It could be Capture or the residue from all the previous guys that filled the carpet with encap. Always extract first cleaning. Always extract after fourth or fifth encap. I don't know how you guys get away with encap only.Are you sure the white residue is from the product?
Wrong. Mixed in a bucket of hot water first.It honestly looks like he just poured the powder in a Cimex tank and went for it.
But I don’t know, but I’ve also never used it for straight encap, because it’s not for that.Wrong. Mixed in a bucket of hot water first.
I'm guessing carpet freshThe green dragon threw up on it!![]()
Well I don't know what happened. The areas that turned white where pretty worn and dark. Maybe the customer used carpet fresh or some sort of scented powder. Whatever happened, I'm heading back tonight to fix it. I'll probably just acid rinse everything.
Ok, I'll do that. CRB to bust it up, then vacuum.I'd give it the best dry soil removal first Damon.
Vacuum at least; pile lifter or CRB, and THEN vacuum it after for the best results.
If it is a powdered carpet deodorizer, that stuff turns clear when wet, but doesn't easily dissolve in water (even with an acid rinse).
We had it happen here. I found out our janitor bought Carpet Fresh and put in everywhere when he took care of the place at night only afterward.
He said he did it because he liked the smell![]()
I had this happen to me years ago with a Karate studio. After every session the instructor would sprinkle Arm and Hammer stuff around. When I cleaned the floor the entire place had that white film everywhere. I was new at the time and very panicked. I cleaned it again and refunded his money.
I'm not sure that this is what is happening at the current place. It seems the places that turned white are the areas where I scrubbed a little extra. But I'll find out.
There are some buildings that are just not easy to clean with hwe. Not being able to close down certain areas, no water supply close by, etc. If encap is done properly and the product works as it should and the building has regular vaccuming done, it shouldn't be a problem. I have one building where we have done it for the 5th year in a row with encap. No residue problems, no wicking, no buckling and the carpet looks cleaner than when we used hwe.Good point. It could be Capture or the residue from all the previous guys that filled the carpet with encap. Always extract first cleaning. Always extract after fourth or fifth encap. I don't know how you guys get away with encap only.
Yep.There are some buildings that are just not easy to clean with hwe. Not being able to close down certain areas, no water supply close by, etc. If encap is done properly and the product works as it should and the building has regular vaccuming done, it shouldn't be a problem. I have one building where we have done it for the 5th year in a row with encap. No residue problems, no wicking, no buckling and the carpet looks cleaner than when we used hwe.
No. I know all I need to know. Green Dragon is not a good encap. I’ll use it as a pre-spray until I have used it all up. I just redid the job and with a CRB to break it up then vacuumed again. I then went over it with my vibe and lightly sprayed Saiger‘s encap and dried the carpet to make sure there’s no film wicking up. Then went over it again with a dry microfiber pad. Worked out good.We have a booth two over from Encapstore, do you want me to ask? View attachment 117806
Good to knowNo. I know all i need to know. Green Dragon is not a good encap. I’ll use it as a pre-spray until I have used it all up. I just redid the job and with a CRB to break it up then vacuum cleaner system. I then went over it with my vine and lightly sprayed Saiger‘s encap and dried the carpet to make sure there’s no film wicking up. Worked out good.
The people at the commercial building stated they never use any potpourri or arm and Hammer fresh scent powder. So I’m convinced that my overspray of this product in the heavy trash areas left a white film. Lesson learned.
It was a zebra afterall.No. I know all i need to know. Green Dragon is not a good encap. I’ll use it as a pre-spray until I have used it all up. I just redid the job and with a CRB to break it up then vacuum cleaner system. I then went over it with my vine and lightly sprayed Saiger‘s encap and dried the carpet to make sure there’s no film wicking up. Worked out good.
I encapped a vinyl plank floor today. Showed up ready to clean the carpets, they didn't tell me they had replaced them with vinyl. Oh well.The products I've used from Damon Williams and his Encapstore.com have been Angry Lemmon and Awesome Encap. Both are excellent.
What pad and machine did you go with?I encapped a vinyl plank floor today. Showed up ready to clean the carpets, they didn't tell me they had replaced them with vinyl. Oh well.
Phoenix and microfiber pad. Used my regular encap product and finished with a flat mop. So far, they haven't called me to complain about any white residue on the floor. Keeping my fingers crossed.What pad and machine did you go with?
It’ll be fine. The amount of polymer has to be so diluted in rtu solution that the film is probably microscopic. I’ve used some encap on hard surfaces and never noticed anything left behind.Phoenix and microfiber pad. Used my regular encap product and finished with a flat mop. So far, they haven't called me to complain about any white residue on the floor. Keeping my fingers crossed.
