MB/PMF Grinder...da best.
I love mine. The only thing I don't like is the max psi on the trigger is 500. Is there a kit to change it to a higher pressure?
Reactions: hogjowl
They make an 800 psi brass valve. Not sure if the plumbing will match up.
CtcClean
Did you use just spray an alkaline cleaner and let it dwell? No acid?
CtcClean
What is the difference between this tool and a cobra hand tile cleaner?
CtcClean
Is there any difference between this tool and the cobra or a spinner hand tool?
icleancarpetz
Rafael Samson
The cobra can be a bit cumbersome and awkward to use in tight areas. If you need to flip it over or use side ways and trigger side ways, that cobra is a pain to use. It's like trying to grab a key and putting it into the ignition and starting up vehicle with an over size mit. Guess that's why it use to be free with the turbo force?
By the looks of that video PMF tool, breeze to use.
icleancarpetz
Rafael Samson
PMF U1590SB Grinder Hard Surface 4-1/2in Wide 500psi Internal Spray Specialty Hand Tools Scrubber Detailer Wand [U1590SB]
Reactions: Condog
Ten foot hideAhose
Two jets instead of one
No vac relief, worthless on this tool
Internal pressure hose
Better rubber grip
Higher pressure valve 800
Reactions: Walrus Gumboot
