Notch your Devastator and Prochem wands if you want to switch your carpet and hard surface Glides back and forth.
The Delrin plastic we use for the hard surface Glides is brittle and can crack if you use too much leverage to pry in either direction.
You can use a Makita cutting wheel or a hand file to easily cut a notch in the splash guard/ wing on these wands.
Sapphire and Evolution wands are not an issue, nor will the upcoming AW29.
