- Aug 9, 2012
- Name
- sam miller
You have 5500 hours on it already!? Do you ever sleep?
Miles oops
284 hours
Just wait till I get back to working on it. I got big plans... It's going to be Yuge!I really bumped this because that other whitemagic thread keeps passing up my views!
1000 hoursLol, mine on the 2015 are original with 1400 hours. The 2016 had them replaced because one popped from a flat spot. I'm not sure what the manual says.
You googled what?View attachment 74519 View attachment 74520
Ok the check engine light comes on and I googled and I'm finding it has to do with the thermostat?
It does go back off and the water temp guage never goes over 210
Also why the 570 and pro1200 must have the same idiot gluing the lid gasket on both failed in less then 6 months.
With that said I replaced my 570's two years ago still doing great.
You googled what?
What is the code?
You know me I read something didn't pull codes or anything,
But it happens when I do upholstery.
Not enough flow possibly, also tile and grout, or if I run out of fresh water.
I'm guessing it's related to the thermostat.
But ya I should have it looked at it's under warranty.
Just asking here to see if anybody else with a DD Sees it.
@Mark Saiger
Air flow, yes. Looks professional... eh eh.Probably allows better Air flow
You don't expect him to wear it all the time do you?Jimmy does
