- Feb 9, 2024
- Name
- Bryce
What is the point of the thing? I read it is to protect the pressure pump from too hot of water coming into it, but the relief valve is after the pressure pump on the discharge side of the system. And it is rated for 165 degrees which doesn't make sense. My heat gets way over 200 degrees so theoretically it should be discharging water into the waste tank all the time...
