The big test is coming.
GeneMiller
gene miller
Sorry to bring this back up to the front but maybe the increased air flow causes the wand even with the glide to lock down on the carpet just like without the glide actually decreasing it's effectiveness. Just a thought.
Gene
t'll be 2020 and we'll still be having this same conversation, and cleaners will still be buying and using 2.5" hose because it WORKS in REAL life.
2.5 is on a rapid decline due to laziness and goodnuf mentality
I had a 100 feet of it on the truck but took it off. Too much of a hassle.
Does help greatly on long hose runs of 350 or more feet.
I don’t know anything about it, that’s for sure!
roro
Ross Craig
I plan on using it 6 or so times a year when my weeny mount gets asked to clean at 250ft
Best you move out of the caravan park jobs and on to the McMansions.:biggrin: We use on both units every day through to the splitter at in-line filter. Invaluable when double wanding.
roro
Reactions: Hack Attack
roro
yeah I'm not planning on dualing with a 36 blower
If I'm reaching past 150ft its not normally the size of the clean..
still kicking myself for not buying this place.. $200k, admittedly leasehold, 3ish yrs ago
Mark Saiger
Mr Happy!
Mark Saiger
2.5 on all 3 vans.... Even in - 30 degrees below zero....
roro
Ross Craig
[QUOTE="Hack Attack, post: 4703737, member: 54762"
[/QUOTE]
similar view to one we were looking at near start of Port Underwood Rd when thinking of retiring to the sounds
[/QUOTE]
Yep, number 17 Port Underwood Rd I think? Less than 2 mins out of Waikawa
FB7777
300 cfm is 300 cfm, it does not travel any faster through a 2" conduit than it does through a 2.5" conduit, it just travels with LESS friction through the larger conduit, therefor PRESERVING available LIFT at the tool.
It'll be 2020 and we'll still be having this same conversation, and cleaners will still be buying and using 2.5" hose because it WORKS in REAL life.
well here we are in 2020 still rockin The 2.5 hose
where is that futuristic prognosticator?
