As with most things in life, simple is most always best.
Which is certainly the case with this incredibly easy to use, tough as nails, beautiful results providing, 14", 2 jet, inch and a half tube, carpet cleaning wand
- Handcrafted in America of premium stainless steel, with a nice matt long lasting finish.
- Internal Flat Face GreenGlide equipped for quick and easy swapping of Glides to best clean the task at hand, and especially close to baseboards
- Super beefy jet manifold assembly that even the clumsiest of techs will have a hard time breaking or bending.
- Weighs a perfect 9 pounds w/ Glide installed
- Comes complete with stainless 11003 jets (6 flow) and an inline strainer
- While not considered a low profile wand, it's low enough to get under most beds and it's triangle shaped head gets under & around furniture amazingly well.
- KILLER suction, with the 1.5" tube, it's a total joy to push, pull and sling around homes and businesses.
- It's 03 jets will be almost impossible to plug up and deliver the water with an amazing impact, so much so you can use much less pressure than 4 or 6 jet wands.
- NO streaks or clashing but the manifold will empty out for a couple of seconds, which is far better than using check valves which wear out and fall apart constantly, not too mention distort the spray pattern and reduce flow.
- FREE SHIPPING TO LOWER 48, call or write for a quote for other areas.
Glides are SO EASY to swap out, this wand is IDEAL for using both Slot and Hole pattern options and not "settling" with the Hybrid. You'll find yourself using the Hole 90% of the time in nice homes, on wool rugs and carpet, and especially on commercial glue downs that can chatter and wear you out with a Slot Glide.
$750 complete
Order a second Glide at time of purchase for 35% off!!
Nylon Ergo Handle option for $35
https://greenglides.com/product/the-simple-14-carpet-cleaning-wand/
