upholstery prespray?
P
prestige cleaner
have job involving cleaning the chairs at reg. account tomorrow custy wants to see if she can extend on reupholstering for one more year, what cleaning agent should be able to remove deep grime and heavily soiled around arms of chair and seat, fiber is made of polyster/ nylon? is power burst to aggresive for uphol. (fiber is heavily, heavily soiled) any suggestions? currently have on truck powerburst, o2 with modifier,( bridgepoint) upholstery pre-spray for the job.
I wouldn't use the Powerburst too high at PH 11.6 ready to use. Use the upholstery prespray you have it should do a fine job.
Upholstery can be unforgiving, you can screw up on carpet and correct it.
Upholstery you screw it up and it's difficult if not impossible to correct. Stay around 9-PH for synthetics and 7-PH or near neutral for natural fabrics.
Good luck!
Mix the O2 up , hot water, about 3-4oz/gal, make a spotting spray of 3-4oz in a trigger spray bottle,
spray it and agitate well with a soft brush
let it dwell for a few minutes
then rinse
anything that doesn't come off, hit it with the spotting spray, agitate, rinse
Rex Tyus
This sounds like a salvage situation. Prequalify that with the customer. If you have JJ start there. Add modifier IF NEEDED. If that don't work Hit it with the hammer. CTI prozyme would be the bomb ditty in a case like this. Use a rinse agent be it a fab set, or Judsons.
If it is synthetic and it passes a color fast test and it is trashed anyway, communicate and go for it.
Is this residential or commercial furniture? If it is residential I would be somewhat more cautious. I would still pull out all stops if she is really considering replacement, or recovering. Often they say that and don't really mean it in which the "do no harm" rule would come into play.
Loren Egland
Loren Egland
Steam Way Upholstery Pre Spray works very well. Any tough areas is where I use it when a milder chemical doesn't quite cut it.
handdi
Randy
we use o2 alot
but also use harvards prespray for cotton prints an so on
works great smell like alot like kleen rites stuff ammonia smell
