May 10, 2013 #1 E EnviroCare Guest What are the main phases that customers search for? Im sure "water restoration" is not common. Carpet driers, flood companies etc etc does anyone have solid stats on what is used?
May 10, 2013 #2 F FB19087 Guest you can use the google keyword tool to get an idea https://adwords.google.com/o/Target...000000&__o=cues&ideaRequestType=KEYWORD_IDEAS https://www.youtube.com/watch?v=kp9cWZgdYcc&feature=player_embedded Reactions: Jason del Norte
May 11, 2013 #3 Desk Jockey Member Cleaning Professional Joined Oct 9, 2006 Messages 64,833 Name Rico Suave Flooded carpet Drying Dry Wood Floors Dry Carpet Restoration Sump Pump Backup Sump Pump Failure Water Extraction Water Damage Water Damage Restoration Water Removal Wet carpet Wet floors Wet wood floors Wet Rugs Vacuum Water Vacuum Wet carpet Vacuum Wet Rugs Each in your city or Cities Each in your County or Counties Reactions: Jason del Norte
