What is the stupidest
Bryce C
DFW
Bryce
name for a carpet cleaning business you have ever seen? Aside from mine...
frank fratto
frank fratto
They must have been using a Bane Clean. At least they had the integrity to fairly warn their customers.
You obviously don't know anything about the Bane Clene? 😂
Pretty hard to make mud with 200 psi's {it can be done}
FredBoyle
Fred Boyle
Role
Years of Experience
38
200 psi?
Their equipment didn’t put out more than 150psi
If you cranked it any higher you blew the stator
Bane didn’t use a pressure pump… they used a sludge pump
Only way to increase flow and impact was to throw 2 #3 jets into an S Bend wand
frank fratto
frank fratto
200 psi?
First, you have to give the stupidest
name of a Carpet Cleaning company???
FredBoyle
Fred Boyle
Role
Years of Experience
38
This AI node can’t be built fast enough …
FredBoyle
Fred Boyle
Role
Years of Experience
38
Frank is the one that is deficient of his knowledge regarding Bane Clene equipment
People that speak the most often have the least to contribute
frank fratto
frank fratto
200 psi?
I would run my three Bane units between 135 and 200 psi for years
and the stator would go out you know 🤔 about every six months give or take six months✌️
The worst names that I have seen could not be shared here, out of taste and respect to all concerned.
One I can print was this one:
The Slamin' Team Get In
The others.... :eekk:
  • Wow
Reactions: Bryce C
Well don’t be different or set yourself apart in any way. Heaven forbid!
I was 23 when I named my business. Do I wish I came up with a more catchy name? Yes :( Is there worse names out there? Yes. Did I overcome it an brand the name of my business? YES :)
Reactions: hogjowl
