original 3 year old car battery on the C4, under year old battery on the Dodge Ram Van
Both were DEAD this AM.
Van would not take a jump start at all. When Greenie installed the unit for some reason he connected the two batteries
When I unhooked the tether the van Jumped right on with the first try. I had my kid take it to my mechanic buddy to get his opinion...
this is his report..
Main battery tests OK, little weak.
Aux battery dead.
Engine charging good, 14.1 volts.
Replaced aux battery, cleaner engine fired right up, but no charging voltage present.
Restored charging power between main and aux batteries removed by customer and confirm
restored charging to aux battery.
Measure key-off draw on battery in excess of 250 mA. (50 mA is industry max standard) This
will draw a good battery down in 3-5 days, a weak one overnight.
Isolated draw to something in the cleaner engine circuitry, and with auxiliary battery
disconnected, draw is reduced to 4 mA.
Further diagnosis required to pinpoint source of draw, but truck needed back on jobsite
now.
Meantime, disconnect auxiliary battery to eliminate draw during downtime.
So what do you think is creating the draw? Roof vents and fuel pump need the Kohler ignition on..
Could it be the ignition switch gone bad?
Aux battery dead.
now.
