Which wand would you use??
Braden bell
Braden bell
Cleaning today out 100ft with the sapphire 370 we just got
The sapphire wand 1.5" tube 12" head is building to 11ish hg" but sure sounds like it's moving alot of air
Our other wand Westpak titanium 2" tube 12" head was hitting 12 almost 13" lift.
Without getting into lift vs. cfm which wand would you use
Braden bell
Braden bell
Also I did not look to see the lift of each wand while off the carpet
Westpac....... I have only found one wand better in headweight... balance..and recovery then the Westpak wand and that is Tom's devastator.
Reactions: TConway
Braden bell
Braden bell
Yes slot green glide on Westpak.
I have seen your opinions on the westpaks Jim. They do stay planted very well, even the titanium one. (We also have the stainless version)
I think the Sapphire inch-and-a-half works every bit as well as the Devastator, it's just lacking the swivel and the window
Both or which ever one you feel best with
TConway
Thomas Conway
How is your recovery, if BOTH are producing good results in that area, then you can run either one.
I would set up the SS 12 for residential furnished homes, and set up the WP with a slot glide maybe, for my open floor giddy up wand to make a little better time.
icleancarpetz
Rafael Samson
The Mach is better and has better linear air flow.
Dont listen to those paid ad shills.
I have the Mach 12 and Dev 12 in my possession I love you both extensively.
Lyman
Lyman
Is the mach 12 titanium a good wand for 800 shipped?
