Your first choice tile and grout product
K
Ken692
looking at my first tile floor cleaning, I have a small portable and no real tile tools. I know I need a brush and was looking for somthing to clean some very dirty grout lines. I have a small steam cleaner but still need the juice.
So far I'm leaning on the cobbs ???
Louis
Louis
If you use cobbs be sure to rinse a lot and check it when it is dry. I learned the hard way. Check for a film left on the tile. I use flex but you can't go wrong with oxy blaster. Spending $$ on good products will save you time, money and your body will thank you later.
We use Cobbs and never had a problem.
If greasy use a bit of stripper mixed with Cobbs powermax
Flex and Enzall both work excellent as well.
Im sure many carpet pre sprays do, but those three are my personal experience
Total_Rookie
Referring to OxiBlaster/ ok.. so is there a difference (performance) in the 2x as opposed to regular 6lb jar? (Magic wand) Taf and DeeDee are class act, and family owned.
Todd Millar
Hey Mikey would you use regular tile cleaner and a spinner on this marble tile?
Procyon, Power Max, Flex w/citrus, whatever is mixed up already.
Don't stress over it.
Reactions: Ken692
Peroxide is bad for wool too. So let's discuss crocking on furniture while we're talking oriental rug repair.
Todd Millar
Thanks, I have Procyon, I will use that and take an after pic and post it here so you guys can see how it cleaned up!!
A Judson product.
Powedered high pH prespray.
Works great, very low dilution rates but spendy to ship.
K
Ken692
Really I can use my pre spray from carpets and it will work in a pinch, that's great. I need to put an order and have some product in stock
on light soil sure.
Keep Zep or any VCT stripper on hand to boost the weak stuff and for that inevitable day when you'll wish your muddah never met your fadder.
Nothing funner than 20 coats of MopNGlow with a layer of dirt between each..
Reactions: Mark Saiger
Cheap porcelain tile will look new.
Grout...who knows
Go alkaline and then acid..scrub both times
No miracles promised
Grout...who knows
K
Ken692
Every product video I check seems like great stuff. I will be testing these few for sure Great info for sure. There is a section of simulated wood, should I avoid this area with the slop? Or pro
Captain America
Shore best is absolutely the best stuff I have found
Especially if you don't have a truckmount. 412/471-3330
I've used both the 2x and regular oxy blaster I think the regular is a little better, I believe there's a different surfactant in the 2x.
They both are great.
